Hi, my 1983 350 YPVS might need a new rear shock, she has been garaged for 10yrs and finally I am going to put her back on the road again, any ideas about the cheepest way to replace the rear shock or modify the existing one so it can be worked/serviced upon.
Thanks Pledge.
You can fit a later type shock from the F2 models which I have on my 83 LC2 which is probably the cheapest route and does away with the toothed belt to adjust the preload but is still adjustable with a "C" spanner or Hagon list an aftermarket one for £300.00. Has the damping gone on yours or is it leaking.
Tony
