skik Posted January 13, 2012 Share Posted January 13, 2012 my local yamaha dealer has sent me o rings and 2 spring like clips to hold my speedo and tachometer cables in place.i cant work out how this is ment to work as the end of the outter cable pushes into the hole in the hub [speedo same as tacho] with no room for a clip.it does have a grove in both the cable and hub hole that the o rings fits but how the hell do i secure it.i could post pics but dont know how.im hoping someone with an old sr might be able to help Link to comment Share on other sites More sharing options...
Moderator mervin Posted January 14, 2012 Moderator Share Posted January 14, 2012 i may have a SR manual will do a link if i have Merv Link to comment Share on other sites More sharing options...
skik Posted January 14, 2012 Author Share Posted January 14, 2012 i may have a SR manual will do a link if i have Merv i have a parts manual for an sr with the single clock[mine has two].it shows an o ring with clip.my question is how do i get the clip on.if you could tell me how to post a pic.it would explain better Link to comment Share on other sites More sharing options...
Moderator mervin Posted January 14, 2012 Moderator Share Posted January 14, 2012 here ya go Link to comment Share on other sites More sharing options...
skik Posted January 15, 2012 Author Share Posted January 15, 2012 here ya go i have a parts manual for an sr with the single clock[mine has two].it shows an o ring with clip.my question is how do i get the clip on.if you could tell me how to post a pic.it would explain better thanks folks.i got it sorted.after hours of scratching my head i figured it out .god dam simple when you know how.[feel a bit stupid now] o could i have that manual link mervin Link to comment Share on other sites More sharing options...
