January 2, 201214 yr Hi, I got a radiator cover for my XJ6 for xmas. In order to change it I have to disconnect and drain radiator. Just want to know before I do this if bikes need any specific anti-freeze/coolant, or whether I can just use the pre-mixed stuff from halfords etc. Thanks in advance. Dan
January 2, 201214 yr Moderator Yes yuo can use the premix from Halfrauds if you like paying for the same stuff you get from your tap WATER , buy the concentrate and mix it yourself 50/50 with water no stronger as it looses effectiveness after that merv
January 2, 201214 yr Moderator you should use distilled water not tap water merv, some people live in hard water areas!
January 2, 201214 yr Moderator Very true Paul, i reckon rain water would be good as well, we have a dehumidifier at home that produces distilled water as well merv
January 2, 201214 yr Author Ok. I'll use distilled then as I live in an area with chalky water. Thanks guys
January 3, 201214 yr Moderator does boiling your water distill it or not. i was told it doesn't. I dont think so
January 3, 201214 yr No it doesn't. It does remove a little of the impurities - that's what you get in your kettle - but not all.
January 5, 201214 yr Author Filled it up, started her up, let her tick over for 5 mins, let her cool down, topped her up as it has dragged some through the pipes. Seemed to be running a little warmer but maybe cos it was just on tickover in my garage....
January 5, 201214 yr Rain water aint good either, its better than tap water but it still contains macronutrients apparently.... Distilled or de-ionised whatever they call it and a good coolent, normally at 50/50, maintains a nice pressure and protection.
