December 20, 201114 yr Hi Guys, The lights on my DT 125 R are pants! i've had a search around this site and Google and have not found a definitive answer. I have read the sticky about 125 lights being rubbish but the lights suggested in that thread dont seem to be 'made' for the bike. Does anyone have any suggestions/recommendations? Thanks in advance. st0f
December 20, 201114 yr Moderator I agree they are rubbish on unlit roads, only good to be 'seen'...not to 'see' with
December 20, 201114 yr Moderator Check the fitting but these may be better. LINKY1 LINKY2 Also look at Osram Nightracer bulbs
December 20, 201114 yr i totally agree with you, i have recently fitted this headlight and its alot better that the standard DT headlight, http://www.polisport.com/motorbikes/produtos.php?ID=45
December 22, 201114 yr Author Thanks a lot for the suggestions guys. Ill check them out and let peeps know how I get on with them. One other question; Is the connector type for an 89 model H4? I have the Haynes book o' lies but it doesn't say the connection type Thanks again
January 6, 201213 yr I found the polisport halo to be a good choice, comes with a h4 bulb and was better than stock.
