trigger85 Posted December 14, 2011 Share Posted December 14, 2011 I have got a Yamaha xj600 s diversion (1994) im trying to find out the vin number so I can apply for the logbook. It says in my user manual the vin number is located on the head stock which i have found but the only trouble is that its a 14 digit number and not a 17 digit number. has any one else had the same kind of issues. any help will be appreciated Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted December 15, 2011 Moderator Share Posted December 15, 2011 if there are only 14 digits then this should be all you need. The standard now is 17 however, 9, 11 and 14 are not uncommon. I am guessing you got no documents with the bike, so no numberplate either. The biggest problem is if it a stolen, written off or imported frame with the import duty not paid. Link to comment Share on other sites More sharing options...
trigger85 Posted December 15, 2011 Author Share Posted December 15, 2011 No logbook as he miss placed it, number plate is on bike, text check came back with the same 4 digits as the end of the 14 digit code. So if it's normal to have a 14 digit code on a 94 plate, then I'll crack on and apply for new v5. Link to comment Share on other sites More sharing options...
