November 30, 201113 yr Hi all I am about to strip a spare engine and am thinking of a re-con. Is replacing the internal seals in the engine a specialist job or can I diy it with care? I am thinking this because of advice regarding 2 srokes sitting for too long and the seals failing once started and warmed up. Is this true? Cheers Geo
November 30, 201113 yr Hi all I am about to strip a spare engine and am thinking of a re-con. Is replacing the internal seals in the engine a specialist job or can I diy it with care? I am thinking this because of advice regarding 2 srokes sitting for too long and the seals failing once started and warmed up. Is this true? Cheers Geo If your handy with the spanners then you can do it yourself. Aye the seals can fail if engine is sitting round for long time,,,,they get all hard an dried out,, BUT can you hook up the engine while its sitting on the floor and see will it start,,,,, be worth your time,,,,,mabey engine is ok as it is
November 30, 201113 yr Author I have had it running but not for a long enough distance for the engine to get hot so not too sure! Can you tell by looking at them or are they squeezed in ?
November 30, 201113 yr Geo " you can"t tell by looking, If its the L/h,seal[ geny side] it pull air thru, resulting in irregular idle. [ higher when warms up] if its R/h seal . it suck gearbox oil thru, resulting in white heavy odd smelling smoke,,, also gear oil can be seen on crank ,when barrel &head off. =
December 1, 201113 yr Moderator Easy to do but it depends if you are just doing the top end or a complete strip down.
December 1, 201113 yr Author Cheers chaps Thats pretty nifty info you have there I am going to investigate this weekend. just 2 questions Is the gear ratio/box the same for 125/175mx If the seals are gone is it detrimental to the engine ? Geo
December 1, 201113 yr Moderator Is the gear ratio/box the same for 125/175mx - I am not sure but an expert should appear soon If the seals are gone is it detrimental to the engine ? - Yes. Re-read Blackhats post If you are going to split the engine it is pointless not changing the seals unless you know they are OK. Just a waste of gaskets, oil and time.
