November 28, 201114 yr Right im after abit of help my iv got a yamaha ybr125 first bike and everytime i leave it on the side stand after abit the bike wont start like theres no fuel it happens if its been left for 10 min or even a few hours its becoming a pain as i just went to the parents was there 20 min max went out and the bike wouldnt start again had to be somewhere so bump the bike to get it to start i have tried leaving it on the main stand and sometimes has the same problems i dont think its right it happens more on short journeys ie from work home which is about 2 mile max anybody able to help i have taken it back to the shop i got it and they said to leave it on the main stand as the fuel cant go throu when its on the side stand which i find silly as its gravity fed
November 28, 201114 yr Moderator maybe a fuel pump problem? dont know much about these bikes but I have heard issues with fuel pumps but it usually manifests itelf on sunny days, but thats not to say this isnt also a pump problem Can you 'hear' the pump when the key is turned? Then can you hear it when the trouble starts?
November 28, 201114 yr Author yes you can here the fuel pump the thing if i leave on the side stand and then come out and try nothing but then if i put it on the main stand wait abit put choke on then sometimes it works but i have always thought once the bike is warm then you shouldnt need the choke
November 28, 201114 yr Moderator youre right no you should not need choke when its warm, cant you demonstrate the problem to the dealer...they are just fobbing you off!
November 28, 201114 yr Author i havnt showed them the problem yet just been in and asked about it i bought the bike 2nd hand its on a 55 plate someone traded it in to get a bigger bike the bike its self is a nice bike just a few problems cheers for the link that does help il have a look in the morning and see if i can here the fuel pump priming
January 4, 201213 yr hi all my ybr 125 got some problems it a list lol 1. won't start (battery ok fully charge, fuel tap flowing, spark plug sparks wounder full, carb has been cleaned, air box clean, got compression, checked fuse and all connections and i even try bump starting down a hill all it did brom very slow till it stopped) 2. so i tried a bit of petrol down the spark plug then tried to start it, it starts but it redline straight away so i turn it off (but i think i put the throttle body in the carb the wrong way round) try if i have in a bit i leave it at that at the mo but any help with the problems would be grateful you can email me at [email protected] at any time it will go to my phone
January 5, 201213 yr i havnt showed them the problem yet just been in and asked about it i bought the bike 2nd hand its on a 55 plate someone traded it in to get a bigger bike the bike its self is a nice bike just a few problems cheers for the link that does help il have a look in the morning and see if i can here the fuel pump priming get a new bike its fuked
