November 6, 201114 yr hi all, does anyone know what blue spot calipers will fit my 1996 fzr600r fox eye .any help would be great thanks mark
November 7, 201114 yr Moderator A proper intro in the new members area would be nice, as for blue spots they all have the same fitment apar from the late radial ones fitted to R6,s and R1,s and they wiull be obvious too see they do not fit
November 7, 201114 yr Most of them will fit I would go for gold spots my self as they have better pistons fitted, if you are offered blue spots with a transfer tube they are off the early Thunder Ace which are Okay but may need rebuilding.
November 7, 201114 yr Author thanks for the replys i have bought some calipers with the transfer tube i think thundercat but they wont fit due to where the bleed nipple is on the side . it catches the fork leg so it cant be mounted on fork ?thanks mark
November 7, 201114 yr thanks for the replys i have bought some calipers with the transfer tube i think thundercat but they wont fit due to where the bleed nipple is on the side . it catches the fork leg so it cant be mounted on fork ?thanks mark Blank off original bleed nipple, then use a banjo bolt bleed nipple? Like one of these http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=banjo+bolt+bleed+nipple&_sacat=See-All-Categories
November 7, 201114 yr Author cant mate its all the housing off the nipple as well iv just been looking on net and i think r1 1999 calipers might fit ? not sure though thanks for the reply
