October 3, 201114 yr Hi Having problems starting the bike. It was working fine till one day I tried starting it and the kick starter goes down really easy and not enough to make the bike turn over. Any ideas?
October 3, 201114 yr Hi croz " you say make it turn over, do you meen its not turning,? [ ie. siezed] or no compression [ ie. turns over too easily] ?
October 4, 201114 yr Author Hi croz " you say make it turn over, do you meen its not turning,? [ ie. siezed] or no compression [ ie. turns over too easily] ? It turns over too easily. I kick it to start it bit there feels like there is no compression. How could that happen from just sitting in the garage for a week?
October 4, 201114 yr Moderator Where is it it sounds to me like it is complete rubbish i will come and collect to save you the problem of disposing of it :babyha: :shakeno: have you checked the sparkplug has not come loose or the head nuts ? Merv
October 4, 201114 yr Join the que Merv " ,, Another thing could be the rings are gummed in to the piston,, when is the last time it was de-coked / take of head and barrel, everthing will come to light,, at worste , a rebore,, £40, from a machine shop,,, and a new piston, clean top of piston, any over-size will be marked on crown,, = .25 or .50
