Hi guys ,
My bike has not been running fantastic over the last couple of weeks so decided to pull the carbs , full off gloopy varnish, then I decided to pull the petrol tap, I had drained off the remaining fuel then all this came out
click on image
th_200920110271.jpg[/.
dont think u are ment to put veg oil in there ..........but thats bad ...... do u know for sure what it is?
Easy diagnosis. Electoplasm. The bike is possessed. You need to call
I would guess the additives stop the old type "varnish" forming but this muck isn't any better.
Do you know if the tank has been lined with petseal or similar ?
IMHO I think it was lined.
The new stuff is ethanol proof, but only just!
sorry guys I have been working away for a couple of weeks so not had time to reply, yep it has a ethanol proof lining well suppossed to be the last lot of petrol I put in was some shell super unleaded, I can oly think of two things
1, the super unleaded has a higher octane level, and its reacting with the por 15 lining or as it more ethenol
2, the fuel at the petrol station as been cross contaminated in the tanks , and with the cost of the petrol and people not buying super unleaded it as sat in there tanks for a while
3 the super unleaded fuel in their tanks was low , and I have filled up using all their dregs
ethanol absorbs/ pulls moisture from the air , it then reacts with the petrol then sinks to the bottom of the tank , I have bought some stabiliser and will brim the tank or drain whats left from now on before putting it away for the year
just dont leave any tanks half empty / full
