Geoclinton Posted September 18, 2011 Posted September 18, 2011 Hoi Guys I have stripped and sorted petrol tank, carb, oil pump,air box, oil tank and replaced the gear oil . I put it all back together again and I seem to have lost the spark.so she won't start. Can anyone recommend a bike mechanic in or near Brighton? I am too busy and inexperienced to be able to sort it. Cheers Geo
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 key on killswitch off Geoff, i'm sure we can help regardless of experience
NEV Posted September 18, 2011 Posted September 18, 2011 Geo, are you getting any electrics? horn, indicator? brakes? if not check fuse, or seeing as how you've had the petrol tank off, check the female terminal on the coil that sits under the tank hasn't been accidently pulled off, Nev p.s check sidestand is up too, or bike won't start
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 There isn't any key or ignition to speak of. only the remains of the paddle switch. She did run when I got her started no probs.the electrics only run proper when the bike is running so I am a bit stuck and running out of time to try and get her on the road. Cheers George
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 Geo, are you getting any electrics? horn, indicator? brakes? if not check fuse, or seeing as how you've had the petrol tank off, check the female terminal on the coil that sits under the tank hasn't been accidently pulled off, Nev p.s check sidestand is up too, or bike won't start NEV sidestand not applicable on these...you just have to remember or pogo round the first left hander :0 ordinarily for a DT175MX the battery and fuse would also be not applicable as they will run straight from the magneto...I think even the early 125's (with points ign) will also
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 Yep She is a 81 mx so should be simple but not to me
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 I checked all wires under the tank all seem ok
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 you didnt reply to my earlier questions Geoff tut tut!!
blackhat250 Posted September 18, 2011 Posted September 18, 2011 Aye clinton " have you meddled inside headlamp,? look for black/white, from ignition to coil, or near airbox, wires coming up from mag, its gotta be somwhere youv been, ,,
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 Cheers will check it out tomorra
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 yeah its no use delving into it only to find the killswitch os on
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 The kill switch is on run with the slide covering the red box. Is the spark obvious when i've taken out the spark plug and rested on the cylinder head?
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 yes but sometimes they can be a little weak and yellowy, best viewed in somewhere shady in a garage really, if its weak thats another issue but at least sparking...remind me...is this a 125 with points and 175 barrel, or a CDI 175?
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 Well all I have gatherd is that its a 175mx circa Nov 1981 not sure about cdi though
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 Well all I have gatherd is that its a 175mx circa Nov 1981 not sure about cdi though But you said it was a 125 1980 in another post? Hi All I have just bought a !980 DT 125 but only have the chassis and engine number. Can I identify the model and year from these and how can I find the original reg? Cheers Geo
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 Yep indeed \I did then I informed the bar forum of its true identity after I had phoned Yamaha with the frame & engine numbers. This bike was advertised as a 125 on ebay so I had the pleasure of a drive to exmoor to pick a 125 that turned into a 175 once I phoned yamee
Moderator Airhead Posted September 18, 2011 Moderator Posted September 18, 2011 Ahh yeah sorry i didnt see that, have a look for a spark when its dark and then we'll take it from there
Geoclinton Posted September 18, 2011 Author Posted September 18, 2011 No spark at all tried switches in various ways . I must have dislodged sumut somewhere I will start to retrace my steps . Bleedin frustrating though I just wanna get on and off road with her.
