September 13, 201114 yr HI Guys I am getting there as regards to the learning curve I have found myself in. I've completely cleared the bike of Exmoor mud now I found a huge clump of it in the air box and on filter too I've drained & cleaned the oil reservoir cleaned carb and dried all the water out of the oil pump housing. I noticed on a previous post that its easy to bleed the oil pump is it the obvious screw head that's at the front to the top left? Also i've bought a new ignition barrel/switch with 9 connectors (2 Boxes) I can only find 2 wires connected to a normal spade switch Does this sound like a rewire job? Hope someone can give guidance. Cheers Geo I will post photos soon
September 13, 201114 yr Author Will have to wait till tomorra Do you want to see the oil pump & wiring? Cheers
September 13, 201114 yr Author Just noticed I have the same bike as your good self I recon i've made a good choice of bike she needs some love though.
September 15, 201114 yr Author Hi The wires I have in hand are the only visible ignition wires.with a paddle switch base remaining. There are a lot of wires going into the light casing What do yer reckon? Geo
September 15, 201114 yr Moderator The pics are too small to see anything Geoff! What is the question again? Invest in a haynes manual
September 15, 201114 yr Author Bought one the other day electrics have always flummuxed me and still do Cheers
September 15, 201114 yr Moderator use photobucket the instrucions are in FAQ's in the new members forum, size your pictures to around 600 pixels wide using paint.net or some other editing software
