Posted September 12, 201114 yr does anyone know of any other kickstarts that will fit my bike that is more beefier i have done broke 2 of them where they slide into the bracket and pivot. i drilled out the dowels and welded a bolt in them for a new dowel but have broke them to. i would like ot have one that just bolts directly to the shaft and pivots at the top where you foot goes do they make this type that will fit my bike?im sure other brands fit it also.
September 13, 201114 yr Author not sure what your talking about i dont see no twin shock kickstarts could you please send me a link to the page of them thanks.
September 13, 201114 yr Moderator Could you not adopt a better starting technique, you shouldn't need to kick it that hard. I can start my 250 by hand and so long as i do it right my 175 goes easily (although not by hand).
September 13, 201114 yr Hi I agree with Cynic, I have in the past broke off the top of my kick start on my twin shock, all because it was difficult to get it to fire up , I was swinging my leg at it like a mad freak. Since that affair back in the seventies,I have learned my lesson and always been very gentle with the kick start, I now take the opinion that so long as the engine is turned over fast enough to produce a spark then it should start providing the ignition, fuel and compression are all correct.
September 13, 201114 yr I always find it best to gently push down the kickstart with your foot until the gears engage then kick from there as your less likely to break anything.
September 13, 201114 yr Or an XT500 Mo, if he'd mistaken it for an XT500, wouldn't be after new kick-start lever; he'd want a new ankle.... maybe a leg!
September 14, 201114 yr Thats why god then went and invented the XT600eeeeeeee Only as an admission of fallibility...... and as the XT500 stood, Darwin was getting FAR too much credit.......
September 15, 201114 yr Author it crankes pretty easy and kicks easy but the dang metal they made of are junk just potmetal or something.
September 15, 201114 yr Moderator But your still kicking it too hard.... I've had my DT over 20 years and been pretty pissed at it sometimes off road, wet, cold, bruised, etc but i have never managed to bust a kick start.
September 15, 201114 yr Moderator most likely a pattern part, in 40000miles i never managed to break one either!
September 15, 201114 yr My lad and his mates the same with their kickstart mechanisms on their scooters, the endless times they've buggered the up the kickstart cogs and stripped the teeth from the half moons, for being to harsh with them. Methinks they need to watch one of those old, black and white Pathe film productions, on "correct methods of engaging the kickstart mechanism" as shown by Mr Jeremy Barrington- Smythe.DFC.DSM,KFC
September 16, 201114 yr My lad and his mates the same with their kickstart mechanisms on their scooters, the endless times they've buggered the up the kickstart cogs and stripped the teeth from the half moons, for being to harsh with them. I'd have to agree, sounds like the OP is flailing away like a man possessed, whereas all that's needed is a good old-fashioned 'long swinging kick' - once you learn it, you wonder how you ever managed to start a bike before! Methinks they need to watch one of those old, black and white Pathe film productions, on "correct methods of engaging the kickstart mechanism" as shown by Mr Jeremy Barrington- Smythe.DFC.DSM,KFC Like this? Watch a master at work - ease up to and just over TDC, then an easy swing, no jabbing, jarring or leaping involved, just a lovely noise. Enjoy!
September 17, 201114 yr I'd have to agree, sounds like the OP is flailing away like a man possessed, whereas all that's needed is a good old-fashioned 'long swinging kick' - once you learn it, you wonder how you ever managed to start a bike before! Like this? Watch a master at work - ease up to and just over TDC, then an easy swing, no jabbing, jarring or leaping involved, just a lovely noise. Enjoy! This is on a relevent bike, even starts it by hand,
September 17, 201114 yr my moneys on pattern kick start,ive had two and one bent with one kick,never even made the full swing,foot slipped off as it bent,genuine only from now on.
October 1, 201114 yr Author i guarantee it aint from me kicking it to hard the the shitty china junk aftermarket kicker i have on it
