September 3, 201114 yr Here is my 1977 DT 100. I have owned it since it was 6 months old, stored for last 31 years.
September 4, 201114 yr Ya fker" an original untouched DT100, do not sell it ,, most have been turned into field bikes , a real beaut..
September 4, 201114 yr Author Hi rh! You got one beautiful green enduro! Hi Yes,not everyone likes it, but it is very 1970's .
September 4, 201114 yr Author Ya fker" an original untouched DT100, do not sell it ,, most have been turned into field bikes , a real beaut.. Yes, too good to let it go. Only 12k on the clock. A few problems to sort (carb & charge fault) but it got its MOT last week.
September 4, 201114 yr One of the most durable bikes of 70s I've ever known. How's the problem rh? Did you fixed her up?
September 5, 201114 yr Author One of the most durable bikes of 70s I've ever known. How's the problem rh? Did you fixed her up? Hi. So far i have replaced both tyres and battery. The air cleaner element had turned to dust, i tracked down a genuine part in Holland. The carb had 20 year old petrol in it and has taken some cleaning to make it run. The front fork seals needed changing along with the kick start oil seal. It now runs and now has a mot. I took it out on the road for the first time in over 30 years last weekend. It has a couple of issues. One it will not pick up and run at high revs under load.I have removed and cleaned the exhaust by burning out the carbon. result, no change. I have now sent the carb for a re build. The other problem is not charging the battery. This results in the turn indicators not flashing. no idea where to start with this one.
September 6, 201114 yr not charging the battery. . no idea where to start with this one. Soarse coil, lighting coil, are still availible from time to time,, on flea bay,,,,
September 16, 201114 yr Hey Guys, Just posting here as I don't know anywhere else. I recently purchased a 1979 Yamaha DT-100, The VIN and Engine numbers are *13A000002 If I'm not mistaken. (Not at home so can't check) It appears to have been used as a trials bike but by the looks of the wiring has been re-wired in the last few years. Overall impressions look good. Superficial rust on the chrome wheels, almost none on the frame. The exhaust is rusted through in several places so i s beyond repair. I was wondering if anyone would care to share with me any advice about rebuilding the bike as I have little experience in the area, However is something I am very interested in. The VIN appears to be very unusual, does anyone know anything about it? Regards to all, Kevin-Andrew
September 16, 201114 yr Moderator type the vin again i cant see it because it overwrites yoour ip address...most annoying!!
September 17, 201114 yr Moderator yes 13A is 1982 AG100 frame number started at 0000101 with a range of 0010000 no way to treat one!
January 1, 201213 yr need help here im looking for dt 100 parts here in the philippines..reed valve and carburator joint to be specific any guyz can help me findng it thnksw....
August 1, 201411 yr Here is my 1977 DT 100. I have owned it since it was 6 months old, stored for last 31 years.
August 1, 201411 yr I have this same bike it was left to rot in a barn its going to take a lot of time and money to bring this beauty back to life but I cant wait to do it can you send me the link for the places you bought the parts from please it would be greatly appreciated
August 1, 201411 yr Hey Guys, Just posting here as I don't know anywhere else. I recently purchased a 1979 Yamaha DT-100, The VIN and Engine numbers are *13A000002 If I'm not mistaken. (Not at home so can't check) It appears to have been used as a trials bike but by the looks of the wiring has been re-wired in the last few years. Overall impressions look good. Superficial rust on the chrome wheels, almost none on the frame. The exhaust is rusted through in several places so i s beyond repair. I was wondering if anyone would care to share with me any advice about rebuilding the bike as I have little experience in the area, However is something I am very interested in. The VIN appears to be very unusual, does anyone know anything about it? Regards to all, Kevin-Andrew hi Kevin im having the same issues cant find the vin number down to some issues i hope that i can sort it if you find any answers to this problem we both seem to have please msg me
August 5, 201411 yr Hi stingy " the V.I.N. number is on the headstock,,,it may be painted over,, rub with emry ,it should appear, The DT100 is the only DT i have never owned [ twinshocks that is] i always thought the seat looked too big in proportion to the rest of the bike, scroll up and see ,,
August 5, 201411 yr Hi stingy " the V.I.N. number is on the headstock,,,it may be painted over,, rub with emry ,it should appear, The DT100 is the only DT i have never owned [ twinshocks that is] i always thought the seat looked too big in proportion to the rest of the bike, scroll up and see ,, Nah! John your wrong! it's the tank too small that's the problem
February 2, 20169 yr Hi rh. Lovely bike. I know that you are not trying to sell your DT100 but if you are ever considering selling it, I would be very interested indeed. I bought the exact bike in this colour new in 1975. Many thanks, Neil Dickson
February 15, 20169 yr Well " they"re getting big money noo, http://www.ebay.co.uk/itm/331772807461?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
