yamaha tdr
iv noticed my yamaha tdr has no petrol light
how wud i no if in gna run out ?
Does it have a reserve position on the fuel tap ??? use that, i have never had a bike with a fuel gauge or light on it,
Merv
You bought the best bike you could there kearnsy123
If you need any info on it gladly help
What does your vin start with? 4gw 4gx 5an?
Will help to tell your expected fuel range
the restricted power output and the best way too get some more power from it
hi yes it has a reserve on the fuel thanks
hows it goin wer would i find the vin number ?
is the tdr that good
and wat can be done to it ?
thanks
Your bikes good for 75/80 std config with the restictions removed but that will be thrashing it in 6th flat or down hill
Im guessing it will top out at 60/65 now and takes a while to get there.
Can be made to go fairly quick in the right hands B) 95/100mph even more with more porting and carb work
Vin is on the head stock. Will have to turn bars to the left and look up from below the right hand fairing to see it.
Best trail type bike around i reckon.
Happy to potter about town or hoon through traffic on the open road, good of road too :)
Great big little bike
Listen to C.B.D. , his is the fastest 125 in the UK. :rolleyes:
sound good il get back to u wit vin
how reliable r they
i had a yz 125 motorcross for a wile and it never gave me a problem
kind simaliar
hi my vin is 5an
im a bit lost at the min
i want to change oil in tdr
went to bikeworld to by some good 2stroke
but fella behind counter said i need transmission gearbox oil
and it does in under the seat
i picked up some fully synt 2stroke anyways
basiclly wat i want to no is what goes wer
how do i drain and how much is needed
thanks for the help
