power valve trouble
This post is 4871 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi guys i am having some trouble with my pv , it was fine a few days ago ,but i turned my key about an hour ago and i couldnt hear my pv servo ,so i striped it down made sure everyting was connected ,wich everthing was so i started it and went on it and its flat until i get to about 35-40 then it starts to kick in so i was just wondering do i need a new pv unit any help would be great thanks
sounds like the PV controller or motor has died , my TDR did this recently, the Reg rec died and put a high voltage through everything blew bulbs rev counter CDi Pv unit the lot , and the symptoms where very similar to yours
