Posted July 20, 201114 yr Well peeps im finally back in the UK, bought my bike back from benson and thought it would be a great idea to slap on those stainless brake lines i bought whilst i was away for a bit of extra bling, got to the last line and found it didnt fit as the banjos were pointing in the wrong direction, so i sent the faulty brake line back and used my original one in place for now, only when i came to bleed to system ive now found that my master cylinder seals have collapsed resulting in no pressure in the system... only when ive come inside to look for more seals, the only kit i can find is from wemoto for £40!, thats a bit feckin steep for a few o-rings and a spring?. does anybody know where i may be able to find a set or possibly improvise with seals from another cylinder in the yamaha range? (XT600 maybe?) cheers all, need a cigarette now, i was so looking forward to having a blast around on it for a week, but no... - Foameh x
July 20, 201114 yr Moderator Thats a bit of a coincidence Steve eh?...sure it's not just air? you wouldn feel any pressure
July 20, 201114 yr Author nope ive bled all the air out of the system, but when i apply pressure through the master cylinder and open the bleed nipple there is hardly any pressure coming out, ive checked for leaks and cant see any... so now im kinda lost on it
July 20, 201114 yr Moderator nope ive bled all the air out of the system, but when i apply pressure through the master cylinder and open the bleed nipple there is hardly any pressure coming out, ive checked for leaks and cant see any... so now im kinda lost on it lots of people bleed brakes by the wrong method...are you one of those
July 20, 201114 yr Moderator might be just a case of stripping and cleaning? here's a link to some generic M/C kits http://the-parts-hound.bizhosting.com/mrk.htm
July 20, 201114 yr lots of people bleed brakes by the wrong method...are you one of those Yeah OG, give the forum a 'master-class' with sketches and drawings and stuff
July 20, 201114 yr Moderator Back bleed em push the fluid back up from the caliper with abpipe and syringe merv
July 21, 201114 yr Author tried back bleeding as you put it merv but still cant get the system to pressurise, sent the faulty braided hose off today so with a bit of luck i may be roadworthy by the start of next week if i can get some seals ordered aswell, its too expensive to run my car
July 21, 201114 yr Well peeps im finally back in the UK, bought my bike back from benson and thought it would be a great idea to slap on those stainless brake lines i bought whilst i was away for a bit of extra bling, got to the last line and found it didnt fit as the banjos were pointing in the wrong direction, so i sent the faulty brake line back and used my original one in place for now, only when i came to bleed to system ive now found that my master cylinder seals have collapsed resulting in no pressure in the system... only when ive come inside to look for more seals, the only kit i can find is from wemoto for £40!, thats a bit feckin steep for a few o-rings and a spring?. does anybody know where i may be able to find a set or possibly improvise with seals from another cylinder in the yamaha range? (XT600 maybe?) cheers all, need a cigarette now, i was so looking forward to having a blast around on it for a week, but no... - Foameh x Hi To obtain the O rings you can get the part numbers for the sizes using the AS 568 'O ring dash numbers', http://www.allstategasket.com/library/Allstate_Gasket_O-Ring_Dash_Sizes.pdf Then all you need to do is find a local O ring supplier and get them to order the ' O rings' Perfluoroelastomer Is probably the best 'O ring Material to use. http://www.toparts.com/Html/ElastomerORingA.htm
July 22, 201114 yr Author cheers nayruf, im pretty sure they are cup seals in the kit though . there are rebuild kits for the XJ900 master cylinders... tempted to try one of those, or change the whole setup to a XJ900 front master cylinder failing that, on the wemoto website they list the rebuild kit for the XJ600 as being the same for the FZR600, XJ900 and FJR1200
July 22, 201114 yr Moderator do what i did with the Z650 replace with a good secondhand one , easier than faffing about rebuilding i got a master cylinder off a 2008 bike from a breaker in cornwall for £35 merv
July 24, 201114 yr Author problem solved, got a bigger syringe and tried back bleeding it again and it worked!, i managed to get the system to pressurise and now it works as good as new! cheers for the tip merv, methink a pint will be in order
July 24, 201114 yr Author spent about 5 hours on the ol' girl today just riding around... didnt put a foot wrong, love it <3
July 24, 201114 yr Author Aye indeed , no better feeling than blasting through the cool dusk air with some Blink 182 playing through the headphones no doubt i will have this same problem again when the replacement braided hose comes for the front, and i have to break in to the system again, e.t.c
