Clutch slip
Hi I have a problem when my bike is cold it seems to jump from 4K-6K rpm when the clutch lever is fully out at first i thought it was the clutch plates which i have replaced both them and the srings the bike ran great for the first few days but now the fault has returned any advice would be great Thanks
Greetings James. is there some slack in the cable? did you use bike specific oil? how about an intro in new members forum?
Hi thanks for answering, yes there is some slack on the cable I have striped the cable off and lubricated it and I am using 10/40 semi synthetic.
is it bike oil James...not general car oil?
yes it is bike oil. when the sliping first started i was using fully synthetic then after reading some forums where they said that this could be an issue i changed back to semi synthetic after the new clutch was fitted.
Have you fitted EBC plates?? My mate Paulfitted new EBC plates to his RD400 recently and new HD springs and it slipped in spite of all he tried evntually he stripped it out again and the new replacement clutch plates where actually thinner than the ones he took out, he put his old plates back in clutch slip gone
merv
merv
Hi there I did use EBC plate but the old plates were badly worn the clutch was great for the first week no slipping.
merv
Not saying its right merv but this could have been adjusted out...no?...using the pressure plate adjuster?
same thing goes for yours James, if the new plates are not as thick then it will all 'bottom out' on the previous adjustment setting. Theres more than just the cable adjustment on a clutch...least thats my experience of em ;)
Paul
I dont think you can adjust it out, the springs hold it in and there are stops on the pressure plate that stop it going in too far, actually the upgrade for the RD400 is XS400 /750 plates that have more friction area
Merv
Paul
Merv
not XS 400 parts in an RD Merv :o
I'm storing that litle gem for the right moment! :P
[/quot
just a quick update I have manged to fix the problem with my clutch I have change the cable and reset the push rod concentric which fixed the problem. Thanks for all your advice cheers
