Bike doesn't like water
Greetings all,
I've been out riding quite a bit and the bike is going well but not in the wet.
If anyone has any advice on this one it would be mucho appreciated:
When it's wet enough to pull water up off the front tyre, the bike will go for a bit, nothing for a bit, then go for a bit a couple of times with maybe a backfire or two and then stop dead. If the engine's hot it will start after a short wait but sometimes go/stop/go/stop again.
I'm suspecting water getting into the coil. The lead is a bit loose at the coil and I've tried to seal it but that didn't work. Taking the plug out it has a bit of orange spark and it looks like that's where the problem is at but I'm not sure if it could be anywhere else. (For a while there I had a little water getting into the top of the carby before I replaced washers and got a new rubber boot).
Before racing out to get a new coil, I just wanted to ask if anyone thought it might be something else. If it is the coil, I can't see if the lead can be replaced and how this might be done.
It runs fine when dry so I just have to work out what the water's getting into.
Thanks,
Gordo
Great and thanks,
Will get onto that and see how I go.
Gordo
