June 27, 201114 yr hi there im new to this forum im at my wits end with my bloody xt 125 i have put 2 new speedos on this bike and all have blew a puff of smoke out of them after a few days i have checked all the connections and have recently found that i have no number plate light bulb in the rear.....could this be the problem ..... any suggestions would be appreciated .as i cant afford another 100 quid for a new speedo .....let me know people thanks again ....james........
May 29, 201213 yr that may be the problem, i had a same kind of problem with my car, i had 100 watt headlight bulb in one side and tried fitting a standard in the other and kept blowing, but if you are not certail, fit a fuse between the power input to the speedo, then atleast the speedo will not blow. moz
May 29, 201213 yr Moderator Probably a bad connection so it is shorting or your regulator isn't working and the speedo is taking the full magneto power.
May 30, 201213 yr I have an XT 125 and my speedo is knackered, after reading this thread I checked my number plate bulb and that is knackered as well.
May 31, 201213 yr When i saw the title from outside the section my immediate thoughts were that posting it on a forum is a slow way to get hold of the fire brigade but looks like it wasnt that bad!
