Posted June 19, 201114 yr hey guys... i went to see this bike today.. the only fault i could find was that the battery was flat after one start as its been sitting there for a while... and that the coolant pipe had been snapped...which is an easy fix... opinions..?? http://www.gumtree.com/p/cars-vans-motorbikes/2008-blue-yamaha-yzf-r125/82334438
June 19, 201114 yr Moderator Hmm coolant pipe snapped , get it repaired and filled with water and before you buy,then get it running to see if the oil and water are mixing together, it could have been left out under that sheet all winter with no antifreeze, engine block could be cracked, the fact is has tax and mot is not a bad start, but if they are not prepared to sort the pipe or get the engine started then adjust the price accordingly or walk away,
June 21, 201114 yr Author Hmm coolant pipe snapped , get it repaired and filled with water and before you buy,then get it running to see if the oil and water are mixing together, it could have been left out under that sheet all winter with no antifreeze, engine block could be cracked, the fact is has tax and mot is not a bad start, but if they are not prepared to sort the pipe or get the engine started then adjust the price accordingly or walk away, cheers fella. had my mechanic check it over today... he replaced the pipe... no cracks... no head gasket change needed... starts up first time.... perfect cheers for the help.
