i think xs 250 has beaten me
Hi
I am very frustrated but i do see the funny side of this ...
well i have built rebuilt a few bikes ever but this f****** is taken me to hell well two of em now cos i bought another
will not run proper nor will the other
will start on one cylinder then other wont run ...
ahh you say .... no I say cos it could start on the opposite then the one that was running previously wont run
so far checked points gap good timed and retimed and some more then fitten new conatcts timed timed again
coils tried loads of different coils
new condeser
so i figured it the engine
so i buy another basket case xs250
swap engine
same thing
contacts timed retimed take off check advance all good
time retime check time a again
Carbs been to cleaned with ultra sound
have two other sets of carbs that do the same thing
go figure
as i type son is changing the exhaust system
with air filters on it will not start at all
take filters off and block pipes and she makes an effort ....
thats the only significent data i can present
HAS any One please got any ideas at all
Jez
going Mad
Well jermiah " you"l be the only thing an XS250 has ever beaten , :D ,,,,,, On a positive side Drewpy , the Y.O.C. Xs wizard will Be along with some suggestions, sounds like you"v covered everythin tho :unsure:
I'm here...
well what do you mean by not running proper? that could mean anything :blink:
if you can described exactly what the bike is doing/sounding and revs etc i will be able to help you!
100psi is not good, its usually 140 psi
the xs's are bloody funny with carbs, if they are not really really clean, and I mean stripped down and ALL orifices blown through and clear you will have issues. float height need to be spot on (26mm)
checked your idle mix tips? bet they are broken off in the carb body (lucky if not)
Hi
Bit more "un-frustrated" this morning
late last night after posting we did notice that when she tried to start on the right it was not as strong as when she tried to start on the left
we swapped coils and got same result so i tried another coil on right .. and now it does try and start on both cylinders
Current status tries to start on both cylinders
sound
possibly missing wont respond to throttle best its run for with out starter turning is about 5 secs
to start last night i had to remove air-box and block/restrict intakes once firing a bit i put air-boxes it the would continue to start ...choke on to start after a while it doesn't like it but still wont start ..
Carbs they have been ultra sonicily cleaned ... it made little or no difference
i have 2 other sets of carb's they have the same result ... same symptoms
I have put a new condenser on made no diff
Points I have gapped and timed using a light bulb timed to the first mark after LF ... I will say that i found this a bastard of a job as the timing wondered as re-tightening screws
but they seem to be on the mark now
I am thinking of the fag paper method but the hassle last time to get them spot on is putting me off
atu bob weights seem too be free
TODAY i will try
putting old condenser back on
some original exhausts
and brand new coils if they arrive in the post
Jez
coils arrived ..... single wire wrong ones .... and i did tell the guy points in fact i ordered new points at the same time
Kill it! Kill it with fire! Then pour Holy Water on the ashes.
I had an XS250 for just under a year many moons ago - I still get nightmares ...
Safe to say it wasn't Yamaha's finest hour .....
tried other carbs back to one cylinder (right) unable to get left firing so took carbs off cleaned left one blew out pilot jets and airways examined needles (tips look to be there) set them at three turns out from full in
now nothing will fire yes .. it has spark ...
i have restored bsa's that people pulled apart in the fiftys and left outside ... and a sr500 that lay in a hedge for twenty years ... this pile of **** defies all logic
vacuum barbs on manifold still got its cap on and the pipe to the pet cap ok?
yeah 1 has cap other goes to petcock
whilst turning engine over with petcock in postion on or reserve petrol comes out prime just dumps fuel
so all ok and fuel cap open closed make no difference
i have even tried swapping cap and line about ... from one intake rubber t' other
re done compression test ... its not a very great tester its a cheapo am-tech i have borrowed and its hard to deduce the fast flickering needle but its hitting 125 psi as best i can see ...
Jez
Hi
sound
TODAY i will try
Jez
hmm had loads of XS250's do this with various causes
from the training I received in the early 80's I'll give you the diagnosis path
Compression check wet/dry
out of spec
Remove Cylinder head check valves for leakage
check bores pistons & rings for wear
in spec
adjust valve clearances to the correct values
set the dwell angle to 22.5 %
set the ignition timing (with strobe) to LF (left cylinder) RF (right cylinder)
Always start with the L/H cylinder when sat on the bike
Ignition timing & dwell are set at the same time you may set the dwell correct then adjust the timing which will then set the dwell to an incorrect value.... reset the dwell then recheck the timing keep doing this until you have the dwell and timing right
check the advance for both cylinders (between the | | marks)
adjust the mixture screws for a steady idle (some engines require the mixture screws to be set well away from the default 1.5 turns out)
check/adjust carb balance
Still running badly
check inlet manifolds for leakage the rubber o ring within the paper gasket can fail (you will see the 'gas track' across the paper section of the gasket)
if OK
check the diaphrams for splits. with a diaphram split this can give you a false reading when balancing the carbs so if you have a split you will have to do a re balance
if this doesn't fix it post up again
out of spec
in spec
Still running badly
if OK
Ok right whats the ?? dwell ?? and whats the compression spec
Thanks for the input
Ok out of intrest today (and the fact i cant seem to leaver the ****** alone
we slapped a mikuni vm34 round slide carb jetted for sr500 single on mr left cylinder no throttle cable just carb
choke fired after three seconds started to splutter & run on one cylinder choke off adjusting throttle stop i managed various degrees of succses and run on one cylinder for around 30 secs
didnt have time after to try right cylinder
carbs stripped again will rebuild next week off for the week end
Jez
Just some of the latest here
Dwell is Points Gap (new one on me) any way that's all good
I chucked a Mikuni vm34 (Jetted for a SR 500) on the left cylinder and with some fiddling it runs well and starts easily it will tick over very nice and not cut out miss or fart at all running one cylinder the plug looks nice too nice tan color
repeated the process on right cylinder all good runs ticks over nice looking plug
so its the CARBS
back too them stripped again blew out pilot holes and set floats (they were previously ultra-sonicly cleaned
back on same shit fires up now on two cylinders wont run for long it is missing and generally running very rough wont respond to throttle
what i have noticed is no matter where i put the mixture screws it makes no differance (I have even removed them) i cant work out where the problem could be
could it be between the float bowls and and main body there is a gasket there that looks very good the tips of the mixture screws look ok under scope
seriously considering getting some 42 mm copper pipe and fabricating a 2:1 manifold
Jez
Not quite, dwell is the time the points are closed,so its the opposite.
so its the CARBS
told you these carbs are finicky, are you really sure those tips have not broken off, can you see daylight with the carbs off and mix screw out?
the only other thing is the float bowl has a fuel run and it did take me a while to ungunge it using compressed air, solvents etc.
drewps
Ahh yes sorry when i researched "Dwell" i came away thinking it meant the time closed ... but the smaller the gap the less time closed = less power charged in the coil .. ?????
Yes you did i did believe but cant see how to get them cleaner but it will be somewhere something ... The crux is three sets of carbs with the same or similar symptons . However we now know ignition is tip top .. Personaly when i have a doubt i keep going back.
I looked at mix screw through a jewelers eye piece had blunt end but we concluded that should be the case however ...
Ive only seen old ones
Ill take em off tonight and have a look see for daylight and get back on that one.
drewps
bowl is deffo ok
but will check again
Thanks for replying
Jez
it is the amount of "time" ie degrees angle over the circumference of the shaft the contacts are closed. This charges up the primary coil and when the points open, the electricity has built up so much in there that is inducts into the seconary and through the spark plug jumping the gap.
the more the coils are energised the fatter the spark.
some weird shit tonight
started mixing up carbs
made up a new set slapped em on it was running a treat on the right cylinder
made up a new left no luck
made last left no luck right going well though
split carbs put right carb on left left ran fine put a left carb on left left ran fine ??? put these together no right
put a marked good right on right no right
got totaly mixed up now suspect we burning plugs out
but i think we are close
VERY well put and now easily understandable
I wonder if it is connected to today's anomaly
XS 250 now starts well and ticks over well tick over ATM a little fast but sounds a lot better and it stays alive
it does try and respond to throttle but it ain't great but well .... Hey one thing at a time
Now the plugs that came with the bike(s) all six in fact were set to or near to what it says in the Haynes 0.7 mm
last night i thought i was getting close but all the plugs seemed to need constant attention apart from one when i examined it this morning it had a smaller gap (possibly dropped) i measured it at 0.4 mm set the others to that and hey presto ... intial prob's gone and bike starts and ticks over well..
Is Haynes wrong >>>>AGAIN.. or is there something more sinister ...
Possibly related to dwell ...gap set to smallest in Haynes book 'O' lies 0.3
thanks for the input Drew
look forward to your thoughts
Jez
