Posted May 30, 201113 yr I was riding and then I glanced at the dials and there were no lights or numbers! I think it is because of a bumpy ride... I have disconnected and reconnected the wiring around the battery but it did not fix the problem. All of the indicator lights and brake lights work and the bike works too.....but the dials are dead. Please help, could this be serious? And what should I do? Thanks
May 30, 201113 yr as everything else is working check your fuses normally a yellow 5amp fuse for digital display and also check around the unit that the conections are all ok.
June 3, 201113 yr Author Just an update in case someone else has the same problem....the dash came back to life on the way to a mechanic!! it probably got scared at the thought of being taken apart
June 4, 201113 yr Author Now you can sell it !, what are you gonna replace it with ? Yes, already have a buyer. Next up is definitely R6
