Hi All, I removed the motor from the bike to paint the frame etc and rebuilt the bike, i had the carbs bead blasted, cleaned them out and replaced the pilot jet and float needles. I also replaced the inlet balance rubbers.
On starting the bike it has developed a flat spot and only improves with the choke on, one side exhaust is running hot and the other a lot colder. i also replaced one exhaust for a better condition one.
Would replacing main slide needle and jet help and also reed valves? Or should i strip the carbs again and check for blockages?
The motor ran fine before which is also a bit confusing, any sugestions will be greatfully recieved.
Thanks,
Mick.
Thanks,
Mick.
Mick,
if it was running fine before the carb strip down , theres your answer , i think they need rebalancing if you have not done that yet , have you put new cables or disturb them form the original routing
deffo carbs
Mick,
deffo carbs
Hi Thanks guys, yes new cables fitted, I did balance and set up the new cables, I will strip the carbs down tonight.
Cheers,
Mick.
Cheers,
Mick.
Carb stripped and found beed stuck in pilot jet, put back together, runs sweet as. Happy days.
Mick.
