Posted May 14, 201114 yr hi i was wondering if anyone could help me?im not sure if my radiator cap is doing its job(letting pressure out) is there any way i can test it??
May 14, 201114 yr hi i was wondering if anyone could help me?im not sure if my radiator cap is doing its job(letting pressure out) is there any way i can test it?? is there any reason to doubt that its working ?
May 14, 201114 yr Moderator The rad cap should only let anything out if the pressure gets too high. you may have an air lock. Never try to take the cap off when, or soon after, the bike has been run as you well seriously hurt yourself.
May 14, 201114 yr Check the coolant level in the expansion tank when the engine is cold then again when the engine is hot .You should find the level has gone up in the tank when hot as the coolant expands in the rad when hot and transfers it to the expansion tank then draws it back into the rad when it cools down.
May 15, 201114 yr Author is there any reason to doubt that its working ? well it just seems knackered for some reason but when it over heated it wasnt doing anything.
May 15, 201114 yr Moderator overheating on a DTR? Thats often a head gasket leak, there are lots of cheap pattern gaskets around and if they are fitted dry they dont last long...been there, got the T shirt
