dtr125 clutch prolem.....need help
can any1 help?..iv got a dtr 125 1992 model,when i ride it the clutch is fine but after half hour or so the clutch push rod unsrews itself and i have no presure on the clucth lever,how can i stop it unsrewing itself?i dont no much about bikes so need has much help has possible.thanks
If you are happy that it is assembled correctly, have a search for "blue threadlock" on evilbay.
yea its all assembled correctly just keeps unsrewing,where would i search that,on google?thanks
There should be a little ball bearing that sits between the primary rod and the smaller section that is opperated by the arm on the crankcase. If that is missing then the unit can unscrew its self.
I would check that before using the threadlock, you shouldn't need the threadlock to hold it. The locknut should be more than enough.
