1978 dt175e enduro restore project
i just got this bike for 400 and i am looking to have some fun
here are the parts i have on order
1 flasher
2 78 YAMAHA DT125 DT 125 175 DT175 HEADLIGHT EAR BRACKETS
3 NOS Yamaha Delivery Pipe Connector 79-81 MX175 DT175
4 Yamaha Pan Head Screw Lot of 17 Part# 98586-05016
5 1978 YAMAHA DT125, OIL PUMP, AT1
6 Yamaha DT175 DT 175 carb carburetor throttle cable
7 YAMAHA DT175 XT125 BRAKE LEVER AND PURCH GENUINE OEM
8 1978 yamaha dt175 dt 175 enduro y28 rear fender suport
9 Yamaha DT175 DT125 FRONT BRAKE STOP SWITCH DT 175 QS1M1
10 YAMAHA DT100 DT125 DT175 HEAD LAMP UNIT & CASE
11 Yamaha DT175 DT 175 Enduro #1010 Two Stroke Oil Tank
12 YAMAHA CLEVIS PIN AT CT DS7 DT IT LS2 R5 RD SR XJ XS TX 1978
13 YAMAHA DT 175 DT175 AIR BOX INTAKE SUCTION PIPE 1978
14 YAMAHA DT400 IT175 DT175 250 FJ600 CLEVIS PINS NOS OEM
15 YAMAHA DT175 DT175MX DT 175 MX FUSE HOLDER GBP 1.75
16 1978 YAMAHA DT175 DT 175 AIR BOX AIRBOX Shipping cost: Sale date: 03/15/11 $34.99
17 Yamaha DT 175 Year 1978 DT175 wire harness
i am restoring to street legal and not worried how it looks
i have a lot more to go and will show the end product
i found most of the parts on ebay and a few at yamahapartshouse
Welcome Shatntat, :) , Enjoy the restoration, & I noticed USA, ebay is brimming with parts, , big number of Dt"s in circulation , lucky sods :D
today i put one the wiring harness
i had to do this before i put on
the airbox and suction tube.
i had to shorten the ignition coil wires
and the magneto wires as well
to make them work with the harness
it was long so they could run without a harness.
here is the list of part for april i will install
1 flasher
3 1978 YAMAHA DT175 DT 175 BRAKE WIRING 125 250 400
11 NOS Yamaha Delivery Pipe Connector 79-81 MX175 DT175
12 90445-05N13-00 HOSE (L200) 2
13 90445-092K1-00 HOSE (L420) 1
so i cant wait till my ssi check shows up on the first
  • 4 weeks later...
217259_204259216273768_100000690722711_582222_881879_n.jpg216435_204259636273726_100000690722711_582225_1391743_n.jpg
206664_204259656273724_100000690722711_582226_4125089_n.jpg208140_204259719607051_100000690722711_582227_6787151_n.jpg217735_204259789607044_100000690722711_582228_6366034_n.jpg206256_204259836273706_100000690722711_582229_7985529_n.jpg206456_204259909607032_100000690722711_582230_7009873_n.jpg
as you can see i have put some new and used parts on
i removed the after market fender
and in the photo of rear tire you can see i am missing the turn signal brackets
my nine didget vin number is hard to find a report on because in 1981
the hiway patrol made 17 diget vin numbers standard
so i was wondering where i can search for pre 1981 vin reports
what is a VIN report ?
Like an AA car check. They use company's like Carfax but because they have a different way of registration (all on the VIN not the reg) they have the opposite problem to us in that our DVLC search everything from the reg number they do everything from the VIN.
shntat
Just for the record, the Highway Patrol didn't introduce Standardisation of 17 digit VIN numbers.
There is certain information that can be obtained from the shorter VIN but this may not tell you the bike history as I do not know how the USA registration works. Or if people like Carfax accept short versions of VIN numbers for checking. I would guess someone must do as there are a lot of USA members there who have older bikes and these have papers (Green slips???) and are registered in the States.
  • 4 weeks later...
shntat
Hi any new news/pics regards rebuild.
All the best Phil
