O rings and washers for pilot screw
Where can I find the flat washers and O-rings that fit on the pilot screw (air mixture screw) on the Mikuni carburetor. All of the items are about 5mm on diameter. Thanks in advance. Phil
I have a question you might be able to answer. On the pilot screw is there just one O-ring and washer per screw or two washers with a O-ring in between? If just one, I assume the washer goes against the spring (dumb ? I know). Thanks for the lead but I'm hoping to find someone on the west side of the pond.
Sorry i am not familiar with the XS carbs but Drewpy will be along in a minute or someone that knows XS,s
and I did not realise you where the other side of the pond so try SUDCO
Found them from another owner. Thanks
