March 15, 201114 yr Where can I find the flat washers and O-rings that fit on the pilot screw (air mixture screw) on the Mikuni carburetor. All of the items are about 5mm on diameter. Thanks in advance. Phil
March 15, 201114 yr Author Allens performance I have a question you might be able to answer. On the pilot screw is there just one O-ring and washer per screw or two washers with a O-ring in between? If just one, I assume the washer goes against the spring (dumb ? I know). Thanks for the lead but I'm hoping to find someone on the west side of the pond.
March 15, 201114 yr Moderator Sorry i am not familiar with the XS carbs but Drewpy will be along in a minute or someone that knows XS,s and I did not realise you where the other side of the pond so try SUDCO
March 15, 201114 yr Author Sorry i am not familiar with the XS carbs but Drewpy will be along in a minute or someone that knows XS,s and I did not realise you where the other side of the pond so try SUDCO Found them from another owner. Thanks
