hi i have a xj 600s diversion which wont run
it sparks fine has plenty of fuel , fuel pump runs fine spins over great just wont catch and run
any body have any ideas ?
To little compression, not enough info ;)
when did it run last, has it stood
Have you seen my signature?
the bike stopped running about 6 weeks ago
it stopped as i was riding along as if it had run out of fuel but this was not the case
i have replaced the fuel pump and the relay assembly that switches the pump but it won't fire
Is fuel getting into the cylinders? So the plugs will be wet with petrol and smell like petrol?
Get some quickstart, take out the air filter, turn the engine over and spray the quickstart into the airbox.
