N0 1, the indicators flash very fast.
N0 2, the lights all work when switched on ,but when i brake the brake light dims instead of brightening.
N0 3, horn works intermittent..
it's a 6 volt system and i don't posses a 6 volt charger. would i be right in assuming this is what i need.
it's a new (so im told) battery .new relay and im getting a feed to the battery through the jenny...
i like most on here am shit on electrics. so can anyone advise.
thanks in advance PASSOLA MAN..:lol:
  On 2/18/2011 at 11:46 AM, up.yours said:
N0 1, the indicators flash very fast.Duff/missing bulb or wrong wattage
N0 2, the lights all work when switched on ,but when i brake the brake light dims instead of brightening.Check the earth at the light, even money the brake light is ok when the lights are off?
N0 3, horn works intermittent..Check switch and connections but its probbably the horn its self.
it's a 6 volt system and i don't posses a 6 volt charger. would i be right in assuming this is what i need.Yep
it's a new (so im told) battery .new relay and im getting a feed to the battery through the jenny...Thats half your problems coverd
1 the indicators all light up, i will check the wattage tomoz.
2 spot on with this jason the brake light is fine when nothing else is being used.also noticed today it worked ok for a short time then played up again ,this leads me to suspect no charge in battery.
3 horn works fine as above,with nothing else switched on .
i will have to scounge blag or steal buy a 6 volt charge tomoz.
cheers jason.
  On 2/19/2011 at 7:43 AM, mervin said:
Check all the earths are good first
Mars calling Earth, Mars calling Earth, are you Ok?, over!
stop messing about you two,,:blink:
this is serious shit you know,,,:eusa_wall:
