February 8, 201115 yr Hi all, my son has a DT 50 MX and the indicators just stopped working. I thought it might be the switch, however, when you turn them on the neutral switch dims as though the indicators are getting power. Could it be the flasher unit or does anyone have any other ideas. All the other lights work fine. Thanks for reading. Hope you can help. Dave.
February 8, 201115 yr Moderator Hi all, my son has a DT 50 MX and the indicators just stopped working. I thought it might be the switch, however, when you turn them on the neutral switch dims as though the indicators are getting power. Could it be the flasher unit or does anyone have any other ideas. All the other lights work fine. Thanks for reading. Hope you can help. Dave. If its the same for both sides it could be dirty switch contacts or bad ind unit or most likely TBH battery condition. HTH
February 8, 201115 yr Hi all, my son has a DT 50 MX and the indicators just stopped working. I thought it might be the switch, however, when you turn them on the neutral switch dims as though the indicators are getting power. Could it be the flasher unit or does anyone have any other ideas. All the other lights work fine. Thanks for reading. Hope you can help. Dave. I know it sounds stupid but are all the wires connected properly. I would imagine it is the flasher unit, i went through 4 on my derby send 50, not sure why it happened but i changed the flasher unit and they worked each time. Im not saying it's that for definite but it's a good place to start.
February 9, 201115 yr Moderator Teach him to stick his arms out like we used too in the old days that was my exact thoughts merv.
February 11, 201115 yr Author Thanks for the help, tried the arms, he's to lazy, kids these days. Got a new flasher relay, never worked, I will try charging the battery and checking the cells tomorrow. I think that will be ok as all the other lights work, will let you know how i get on. Cheers Dave.
February 11, 201115 yr Moderator Thanks for the help, tried the arms, he's to lazy, kids these days. Got a new flasher relay, never worked, I will try charging the battery and checking the cells tomorrow. I think that will be ok as all the other lights work, will let you know how i get on. Cheers Dave. I dont think the headlight is from the battery but direct from the magneto and the tail light is not much load from the battery so its not surprising they work ok
February 11, 201115 yr Moderator I dont think the headlight is from the battery but direct from the magneto and the tail light is not much load from the battery so its not surprising they work ok Wiring is the same as our DT's OG, you could damn near swap the looms straight over.
February 12, 201115 yr Author Thanks for all tour help. I changed the flasher unit and charged the battery all works fine now. Got a new battery on order as this one is not holding a charge for long. Thanks again. Dave.
