February 8, 201115 yr Hi all First post Where does a conical air filter fit on? What's the best sprocket set up? And is there anything I can do to the engine? Thanks :-)
February 8, 201115 yr Moderator Hi all First post Where does a conical air filter fit on? on the intake of the carb?? What's the best sprocket set up? small front big rear And is there anything I can do to the engine? Thanks :-) yes derestrict it it will do 40/50 mph then or at least my priller with the same engine did
February 14, 201115 yr You can buy big bore kits to take it up to 80cc. Polini do one but they are not cheap,you have to buy a cylinder and piston and a bigger carb. It would be serious fun,might get one for my son.Check on ebay. If you can send me your mail address I can send you info.
October 4, 201114 yr http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=dt+50+coil De-restricts top speed and improves acceleration in your scooter instantly! Simple plug and play design means you will no longer be stuck in traffic. Factory CDI's cause your scooter to stop producing power to prevent them exceeding 50kph. This plug in performance part allows you to overcome this restriction.
October 4, 201114 yr Awwwwwh!!, brings back memories of my DT50... if your has the registration number of G237MYA name any price and i will buy it back... Conical filter fits on the carb, if you take the rubber pipe off your airbox it should fit in (bit of a squeeze though) big bore kits are also a good idea, mine had a 60cc big bore kit, BigOne exhaust system and the largest front/smallest rear sprocket i could find, it was good for 55 on a flat but realistixally 40 was a comfortable cruising speed
