January 23, 201115 yr Hi I have a RD 350 ypvs and I cant figure out what the 3 fuel tap positions down, up, and rear horizontel do, is there a reserve on the bike or is it only prime etc. Thanks jgp
January 23, 201115 yr Moderator I assume this is a vacuum tap. it has a small pipe fromthe tap to the inlet /carb as well as the fuelpipes i which case it could well be the same as my TDR down for on, middle for prime up for reserve i think i am sure someone will be along to confirm/ correct my comment soon Merv
January 23, 201115 yr Moderator If there is only one pipe (fuel) there will be no prime position. If there is another pipe that would mean it is a vacuum tap and it will have a prime position. Myself I would think it is not a vacuum tap and I will hazard a guess that down is ON horizontal is OFF and up is RESERVE. ...Paul
January 24, 201115 yr Down = Hell,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,your gonna drive like a mad man Up = Heavin,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,you have burnt all your fuel Middle = Earth,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,no money to fill up tank
January 24, 201115 yr on my rdlc it's as paul says. can anyone tell me iff the ypvs exhoust will fit the rdlc,(,appoligise for pouching your topic).
