January 9, 201115 yr Wondering if the engine parts (or any parts) are interchangeable on the different R5 years? I have a 1970, and will need to do a little work on it. Thanks
January 9, 201115 yr Moderator Wondering if the engine parts (or any parts) are interchangeable on the different R5 years? I have a 1970, and will need to do a little work on it. Thanks Not 100% but they only did the R5 for 3 years. I doubt they changed much. Probably find a lot of RD350 parts will fit too. Yamaha are pretty lazy that way.
January 9, 201115 yr If you go on the yamaha-motor.com website which is the USA site and click on Sport then parts and service and view parts catalog and select motorcycle you will find a parts catalog that goes back to 1963 and shows the 1970s R5 parts so you can compare the part numbers .Tony.
January 9, 201115 yr Moderator that yam site is good i have the european parts list and a PDF of the R5 gen workshop manaul for europe if you need one and this article is good r5 resto merv
