Conserned about y.p.v.s
should i get a multi meeter and test it? and it seams to have plenty of power atm so dn what to do, btw how do pin it open? and will it make a diffrence?
  • Replies 41
  • Views 12.9k
Multi meter is one way to test it, a 9 volt battery 2 wires and a small light bulb works if you don't have a meter.
Pinning the PV open will cause you to lose all bottom and mid range power, in exchange for a huge kick up the ass when you hit 6-7000rpm. Not a great idea for the road because it will need to be ridden like a hooligan.
btw where abouts are you from?
Barnsley neer sheffield. and i do ride like a hooligan ;) and would it be like rideing a yz 125? usta have one of those and it wasent bad on the road :D
and how do u test with the light bulb?
Not like a YZ, they have a wider power-band and some bottom end to keep you moving.
Get a working bulb from a torch or similar. Fix the wires to the terminals and battery as shown. Wire as below, if the bulb lights you have a circuit.
ok thanks, will try that tmorrow :D, btw the bike dose about 70+ is that right or dose it sound restricted?
Doesn't sound restricted to me, restricted is around 55mph. Are you sure your PV isn't working right  :blink:
i can take a vid if you like but it just gos clockwise. when i got the bike the wire was in the block and hasent made no diffrence to speed earthing it but i have a recept saying its derestricted. anychance a dealer could have "remaped" the cdi?
Not a chance, if they could remap DTR cdi's he would have a queue for miles of people wanting it done.
Vids are always good B)
ok then, will take a vid tmorrow of the powervalve moveing any ogther pics i should take?
Yeah a pic of Olga Kurylenko naked would be nice B)
who ??? haha going  :offtopic:
You asked if there were any other pics needed.  :P
Olga Kurylenko :eusa_drool:
ohhh her yer just have to find them she sent me the other day ;)
not had time to take a vid but im happy with the speed atm so il just take it to an expert/ mate when i get fed up ;)
You didnt need to cut the black one! Only the black with green stripe cable is required for earthing the cdi.
All i did was add a piece of cable to the other side of the original connector block by crimping a bullet head crimp on so i could remove if i wanted and earthed it to the top yoke. Im not sure why you have cut the black one aswell as its totally irrelevant :mellow:
to put the green and black wire to the black wire
But theres no need to make it more of a job than it is, i found it alot easier and tidier to just earth the black/green cable to the bottom yolk but thats just me ...
i tried earthing to battery and still dident work.
Easiest way to earth the PV Ryan. ;)
The black wire is the earth wire, so isn't irrelevant. ( see above)
okay i get you now, i didnt understand the other pics,
But My ways still easier to explain :P
