Posted July 18, 201014 yr hi i have a 89' TDR 250, iv stripped an repaired her engine may times but i have one problem im confused about, after 3-4 mins ride i lose power then she runs on 1 cylinder, iv changed fluids, cleaned carbs and checked spark but its the same. iv got a small leak in gear oil seal but everything else is tip top. please help cos the missus is on my case for spending to much time with it. thanx
July 18, 201014 yr Moderator Tank cap not venting properly ??? coil breaking down when it gets hot ??? Oh and when you get too my age you go spend time with the bikes to get away from her moaning i will also mention http://tdr250.co.uk/forum/index.php a tdr 250 specific forum, you will find me there as well as a lot of people that know a lot more about TDR,s than me
July 19, 201014 yr Tank cap not venting properly ??? coil breaking down when it gets hot ??? Oh and when you get too my age you go spend time with the bikes to get away from her moaning i will also mention http://tdr250.co.uk/forum/index.phpa tdr 250 specific forum, you will find me there as ell as people that know a lot more about TDR,s than me Mervin, don't forget the nagging. The nagging never ends.
