Carb Securing
discobandit
This post is 5055 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi,
I'm having problems with the Carbs coming away from the boots thus letting in air.
I can't tighten the sercuring ring any tighter as this distorts to boot creating the same problem.
Anybody got any ideas?
Cheers
Gary
try wrapping the carb outlet with some electrical tape or something that will be pliable enough to seal small gaps but be able to make the carb alil bigger so you can tighten the boot, maybe try a bicycle inner tube it would work well
