Headlight Lense MELTED....
gbabcock69
This post is 5194 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have a 2006 XV19s (The big Stratoliner) and at the base of the headlight lense where the High beam shines through, the plastic lense has melted and sunk inward. I suppose this happened due to the heat of the high beam shining through the PLASTIC lense.
I wonder if anyone else has had this problem????
I hate to go out and buy another PLASTIC lense for about $240 BUCKS just to have it do it again.....
Any Ideas????
It sure would be nice if someone made a GLASS lense for these headlights.
Regards to all
Gary
Have you fitted a bigger headlamp bulb???
if sothis could explain why it has melted cos the bigger the bulb the more heat it puts out, I would go too a dealer and if they are good they will tell you if others have had a problem, if so fire a few mails off to yamaha themselves and see what hey say
merv
merv
NOPE ! This is the STOCK bulbs...........
