July 3, 201015 yr I have a 2006 XV19s (The big Stratoliner) and at the base of the headlight lense where the High beam shines through, the plastic lense has melted and sunk inward. I suppose this happened due to the heat of the high beam shining through the PLASTIC lense. I wonder if anyone else has had this problem???? I hate to go out and buy another PLASTIC lense for about $240 BUCKS just to have it do it again..... Any Ideas???? It sure would be nice if someone made a GLASS lense for these headlights. Regards to all Gary
July 3, 201015 yr Moderator Have you fitted a bigger headlamp bulb??? if sothis could explain why it has melted cos the bigger the bulb the more heat it puts out, I would go too a dealer and if they are good they will tell you if others have had a problem, if so fire a few mails off to yamaha themselves and see what hey say merv
July 3, 201015 yr Author Have you fitted a bigger headlamp bulb??? if sothis could explain why it has melted cos the bigger the bulb the more heat it puts out, I would go too a dealer and if they are good they will tell you if others have had a problem, if so fire a few mails off to yamaha themselves and see what hey say merv NOPE ! This is the STOCK bulbs...........
