Turn signal cancelators
My turn signals quit auto canceling after I turn on my 82 XJ 400 Maxim is there a fuse blown? at the same time my speedometer quit too! bad day! the cable is good and greased and turns easy?
get the speedo sorted and the self canceling will return there is a sensor in the back of the speedo that senses the distance travelled and cancel the flashers if it is the same as the RD,s
Thanks Mervin, and how do I go about getting the speedo sorted?
Can you not just manually cancel, like the rest of us? :lol:
Jealousy will get you nowhere!
Given how often I see cars that have not cancelled their indicators, I don't see the point myself.
  • 1 month later...
I disconnected the speedo cable at the wheel, hooked my electric drill to the cable put it in reverse and presto..my drill does 20mph! plus after a bit my right signal canceled! turned on the left blinker and after a bit off it went! So I bought a new speedometer drive and all is well! my auto cancelers work again! so all you with manual turn signals eat your heart out!
PAH - fancy automatic doo-dads... just one more thing that go wrong :lol:
