aerox100 viberates :-S
hey guys when i accelerate off my aerox100 vibrates as its pulling away and it dont feel normal for it to act like a viberator lol,does anyone know why my bike could be doing this when i go accelerate off? And the bike wont go above 40 it used to do 60 and the revs wont go about 6K used to go upto 9K plus when doing 60 mph does anyone know why any of this is happening?
does anyone know?
does anyone know?
it might be the clutch my aerox 50 used to do that i changed the clutch and it was fine after that
i have already had new clutch and drive belt fitted to my aerox100 and new throttle cable fitted
is your tick over set high?
at 2000rpm the lights flickered and engine didnt wanna stay running so the garage has put it to 2500/3000 and engine wants to stay running but when im riding to slow traffic the bike shudderes like viberates from the middle of the bike all the way down to the back end
my guess is either i need new piston
or
new rollers
or
the jets are blocked or need changing
or
the drive belt and clutch needs adjusting
or
the transmition needs changing
sound like there is summat going wrong there have you seized it?? run out of oil?? or bent the crank when the new clutch was fitted which in turn has shot the seal, i did bent the crank on a pug sexless vibrator once putting the engine back together, expensive job that was
merv
ah right would that explain the fiberation and loss of speed? or could it be because the drive belt is on too tight?or is it a sign my pistons are on their way out?
  • 5 months later...
This happened to me too on my 50cc aerox.. Just clean your jets in your carb and clean the whole carb inside out. Make sure its all put back together right tho, Check your reed valve too..
