January 1, 201016 yr hi to all yamaha owners, i have just bought a valve spring compressor to take the valves out my 1981 xs250,it just bends and i cant tighten it down anymore to get the collets out,it says it does motorcycle on the box, but can anyone give me any help please. thanks mike
January 1, 201016 yr Moderator with a socket under the valve to support it, and another socket over the valve spring retainer. give the latter a wack with the hammer to break the seal of the colletts on the valve stem. Your compressor should work then drewps BTW to the YOC
January 1, 201016 yr Moderator with a socket under the valve to support it, and another socket over the valve spring retainer. give the latter a wack with the hammer to break the seal of the colletts on the valve stem. Your compressor should work then drewps BTW to the YOC You can't beat the heaviest spanner in the box
January 1, 201016 yr Moderator with a socket under the valve to support it, and another socket over the valve spring retainer. give the latter a wack with the hammer (BIRMINGHAM SCREWDRIVER) to break the seal of the colletts on the valve stem. Your compressor should work then drewps BTW to the YOC correct terms for the tools please Drewps
