cam shaft noise? 125 dragstar
appealmobile
This post is 4993 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Am stuck in Germany with my bike.
Was motoring comfortably at 50mph when I lost power and almost stalled.
I obviously pulled over and it kept running BUT with quite a loud rattle/knock coming in at a faster engine revs. I first thought it was a big end, but later presuumed was a sticking valve.
It's quiet at 20 then it kicks in.
Got the rear head off so far as I believed it to be from there.
Question should both timing marks on each cylinder be at top at the same time or should they be opposite for each cylinder.
I am sure I can work it out in time, but am still wotking on it outside a friends flat.
So far no obvious damage to rear cylinder cam shaft or valves and about to remove the front head to check
I also thought it might be the drive wheel of the timing chain.
Anyone had similar experience?
  • 10 months later...
