hi guys --
i'm hoping to try firing up the old ct1 175 my son & i have been working on, that i've posted about here a few times
(thanks for the help, by the way!), and i'm such a complete novice regarding motorcycles that i'm not sure how you properly fire one up. i'd like to get all my 'ducks in a row,' so as to avoid stupid mistakes.
here are the things i'm aware of (most, if not all, are probably incredibly basic to you guys):
ignition switch on
petcock open
fuel in tank
look to see if fuel flows down hose to carb (it's a clear hose)
transmission in neutral
tires aired up
choke knob pulled out
oil in gearcase
2-cycle oil in autolube tank
is there anything i'm missing? do you have to have the clutch lever pulled when starting if it's in neutral?
and does the battery under the seat have anything to do with starting, or does it strictly power the lights only?
thank you!
hi guys --
ignition switch on
petcock open
fuel in tank
tires aired up
oil in gearcase
thank you!
That just about covers it, make sure the kill switch is OFF if it has one, I would be checking it sparks first too.
...Paul
I think the battery wont be needed as it will be for horn / lights / indicators
I always pour a little fuel into the bore and then put the plug in before I would kick it over.
