September 26, 200916 yr where can i buy a swinging arm assembly for a lot less than £200 for my 1982 rd350lc. or is their a way around re-packng the worn bushes.
September 27, 200916 yr Moderator I thought you could replace bushes like the xs i have. usually they are made of nylon plastic but I have a set of bronze which keeps things in check. you might be able to keep up with me on the twisties then
September 27, 200916 yr Author cheers drewpy,i was told by a certain shop in bolton that i would need the whole shibang,but i only need the bush set, £25 from anywhere on the net im told, keep up with you. who you kidding
September 29, 200916 yr Replacement bushes can be fitted to your swing arm. Another case of your battery needs a new bike syndrome. To help the new bushes last longer it would help if you lost 50lbs of ugly fat. Cut your nose off. ATB J
October 1, 200916 yr Moderator i think they use the same bushes as the aircooleds and the XS,s so should be easy to find merv
October 1, 200916 yr i think they use the same bushes as the aircooleds and the XS,s so should be easy to find merv That is true but the arm just need shiming ( 2402212700 ) from here loadsa play at the rear wheel can be removed with a couple of extra shims and a few mins to fit Regards Jim
October 2, 200916 yr Author thank you all for your replys,exept you joshua2{only kidding}im on to it. just pulled the throttle cable out today and the oil pump cable section has frayed ,the cable is a genuine yamaha part, 12 months old ,are the after market replacements better. Edited October 2, 200916 yr by up.yours
