XS 500 Posted August 29, 2009 Share Posted August 29, 2009 Ok, now its confirmed, I am a idiot I was trying to remove the clutch basket today on my XS 500 and it cracked!!! Not alot, but a small crack is visible. Now I wonder, do I have to replace it or can I drive with it? Link to comment Share on other sites More sharing options...
yoda Posted August 29, 2009 Share Posted August 29, 2009 Ok, now its confirmed, I am a idiot I was trying to remove the clutch basket today on my XS 500 and it cracked!!! Not alot, but a small crack is visible. Now I wonder, do I have to replace it or can I drive with it? Weld it. Link to comment Share on other sites More sharing options...
plain old dave Posted August 29, 2009 Share Posted August 29, 2009 Weld it. I would at least consider a different one. Check your local junkyards and Epay. Last thing you want is bits of weld getting in your oil. Link to comment Share on other sites More sharing options...
XS 500 Posted August 30, 2009 Author Share Posted August 30, 2009 I would at least consider a different one. Check your local junkyards and Epay. Last thing you want is bits of weld getting in your oil. The crack is fine as a hair and only two of the standing parts are flexing a bit, all the others are stiff as before. Is there a risk for a total disintegration if I drive with this? Link to comment Share on other sites More sharing options...
jordanscycles Posted August 31, 2009 Share Posted August 31, 2009 The crack is fine as a hair and only two of the standing parts are flexing a bit, all the others are stiff as before. Is there a risk for a total disintegration if I drive with this? definetly, just get a used clutch basket. Link to comment Share on other sites More sharing options...
Moderator mervin Posted September 1, 2009 Moderator Share Posted September 1, 2009 if the Xs500 bbaskets are the same as the RD ones then PGM have replacement kits. if you get a replacement secondhand one get the crank pinion as well as they are matched i reckon they have numbers on em that have to add up too a specific number, and they could well have rubber shock absorbers in em so make sure there is no/very little play between the basket and the gear it is riveted too merv Link to comment Share on other sites More sharing options...
