dt 175 ignition help
yazholes
This post is 5570 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi i have just brought a realy cheap dt 175 sight un seen (silly move i know) and i just found out why it was so cheap the wiering is all disconected. i was woundering if i could get some help please.
the magneto has 6 wieres: brown, black, red/white, yellow, green and blue
the CDI has 6 as well but in 2 lots of 3: lot 1: brown, black, red/white lot 2: black, black/white, orange
im gessing the brown, black, red/white on the magneto go to the same colour on the CDI but where do the rest go? and there are all these other wiers do i need to do any thing to them or just get rid of them.
im just riding in the bush so i just gota get the old girl runing any info is good info thanks
Link to comment
Share on other sites
Black/white to kill switch, orange to ignition coil, black to chassis. The other colours from the magneto are lighting and battery charging coils so depends on whether youre going to run with lights and a battery.
...Paul
Link to comment
...Paul
thanks for the super Quick reply
ive done as follows magneto wier to CDI
magneto CDI
red/white to red/white
brown to brown
black to black to chassis
and the orange from CDI to coil. still no spark, the only wiers that have power from the magneto are the yellow and green is this normal if so how do i get power to the CDI. the kill switch can be left disconected hay. thanks
Link to comment
magneto CDI
brown to brown
What have you done with the black and white wire, as that goes to the kill switch and if its earthed then, no spark.
The CDI generates ALL the power it needs from the mag, the ig system is completely self contained so if its a bush basher you can sling most of it, battery included.
Link to comment
another quick reply i like this.
cool thanks mate i dont have the black/white wier conected to any thing its just sitting there its just a single wier hay. so does it sound like ive got it hooked up right. thanks
Link to comment
Right give this a try,
brown to brown, red/w to red/w and black to black but NOT ground.
Now with lot 2 from the cdi orange to the coil, black and white NOT earthed and black to chassis.
Does that make sense?
Link to comment
i did what you said and i kicked it and it gave me a small zap then i did it a few more times and it wouldnt zap me again what does that mean, shouldnt it be a pritty noticable shock if it zapes me. thanks
Link to comment
Zaped from where? were you hanging onto the plug?
Thery are all good connections arn't they not just twisted wire and gaffer tape?
Have you a fresh plug to try.
Link to comment
hay mate thanks for your help. i got spark again like i had yesterday but its not enough to arch out the spark plug. i got a new plug and tryed it again but still only a little zap, could the magneto not be sending enough charge.
yhar i had my finger on the tip of the plug and it arched through my hand to the kick start
there all factry conections and ive unpluged and pluged them back in incase of corrosion. thnaks
Link to comment
Check the resistance values of your magneto source coil = 420 ohms +- 10%............Brown to chassis
Check the resistance of the magneto pulse coil = 12.4 ohms +- 10%...........White / Red to chassis
Check the resistance values of the ignition coil, Primary = 1.0 ohm =- 15%, secondary = 5900 ohms +- 20%
Link to comment
ok thanks mate ill give that a go, if it is the magneto is there a way to repair it, it sounds like it just needs a cleane up it was sitting in the guys shed for a while and it had mud all over it. where can i buy parts for this bike is there a place on the net. thnaks again
Link to comment
Mighjt be an idea to get a proper flywheel puller first, ( I think it has a 27mm thread) take the flywheel off and have a look at the components of the back plate to see if all looks well, not rusty and full of crud. As for parts.i use ebay, wemoto, motolink, ebay...and for genuine yamaha parts ...fowlers of Bristol
Link to comment
ok thanks mate. so how do i remove it take the nut off then do i need some sort of puller to remove it. thanks
Link to comment
Just an idea but have you re-made the connection between the plug cap and the fat lead from the ig coil as that can get all shitty real fast and ruin your day.
Link to comment
I use one of these
To get a grip of the flywheel, while the centre nut is undone, works best with something between the chain and flywheel (strip of inner tube, rubber glove etc)
Then use a pupose made flywheel puller (27mm thread) like this
to remove the flywheel. The chain type wrench is also used when re torqueing the centre nut on re-assembly.
Thats a good point from Cynic though...an easy check to make on the HT cap connection.
Link to comment
I use one of these
OG i wish you would put some effort into your replies............. :D
Link to comment
cynic: please don't be so hard on old git, he has been to the coast and developed food poisoning at a french restaurant from
"Le sea bass, stirred"
they say, you are what you eat.... :hungry:
Link to comment
:rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
Link to comment
