June 26, 200916 yr Moderator Does anyone know if there is a manual or parts list for the later square swing arm, right hand side oil tank DT175MX. All the online stuff only shows the tube swing arm and seem to end in '81. The Clymer manual is about the same and I brought what was described as a "service manual" on disk from hbay but it is just a load of badly photocopied sheets converted to PDF and crap. Cheers.
June 29, 200916 yr Moderator Does anyone know if there is a manual or parts list for the later square swing arm, right hand side oil tank DT175MX. All the online stuff only shows the tube swing arm and seem to end in '81. The Clymer manual is about the same and I brought what was described as a "service manual" on disk from hbay but it is just a load of badly photocopied sheets converted to PDF and crap. Cheers. Haynes manual 210, Yamaha 100,125 and 175 trail bikes isbn 1 85010 300 3 Runs up to 1985.
June 29, 200916 yr Author Moderator Thanks Cynic. I got a Clymer one because I heard it was the best but it is still lacking in a lot of departments. Cheers
