June 25, 200916 yr what are the symptoms of an overheating 2 stroke air cooled yammy? and what happens if my bike does overheat? (I havent yet, but living in the desert here its gonna be in the 110+F soon enough, think i should know beforehand) - thanks.
June 25, 200916 yr Moderator Not good. Locked back wheel when the engine seizes. Before that loss of power and pinging noises.
June 26, 200916 yr Hi I live in the heat too. Don't over rev the motor in lower gears. Add about an ounce of oil to a full tank of gas. This will help. Don't overdo it or you'll be blowing lots of smoke and it may foul the plugs a lot. regards.
June 26, 200916 yr Author thanks sluggo, cna you define "over rev"? lately, in 5th gear at about 4k rpm it seems to want to bog if i try to speed up. if i drop to 4th and runup to speed and then shift back into 5th it works better. is that a sigh of it getting to hot? I only have to ride about 14 miles in the city to get home. average speed is 40-45 mph. should i shut it off at stoplights? I really need all the advice i can get since i dont want to kill it by overdoing it. and it will be way more costly to drive my suburban for 3 months. (but not as costly as destroying my motorcycle)
